show snmp traps configuration
Description
Shows the current state of whether SNMP traps are set to occur when switch configurations are changed/saved.
Default
N/A
The following example shows whether SNMP traps are set to occur when switch configurations are changed/saved:
# show snmp traps configuration
SNMP Traps for configuration change          : Disabled
SNMP Traps for configuration save            : Enabled
This command was first available in ExtremeXOS 22.1.
Platform Availability
This command is available on all Universal switches supported in this document..
